There are commercially available grounding straps made of woven steel. They would be far better than dragging a chain behind you.
It's been mentioned here before, but a van/car will not make a good shield against magnetic fields. Electric fields yes, but not magnetic.
Strong electric fields, those that are significantly stronger than naturally occurring fields, are hard to come by. Even under hydro lines. So I doubt you are sensitive to them.
My guess is, if you feel better in your car or van, which are rife with EMI while running, then your symptoms might be best treated through counselling.
