Making a circular clock
Discussion in 'The Projects Forum' started by FroceMaster, Jan 29, 2016.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi
    Have this plan of making a clock with time, minut and second hand
    If i use 3-4 LED in series and use a transistor to drive it i will still have 180 outputs
    If i use 3-8 line driver and a ex 74hc375 or similar to drive it i would end up with 64 output. And then 3 sets of that. All driven by a microchip ex 16f1509
    Is that possible to do or do i have to total rethink everything
    Any hints
    Logic circuits and microchip is fine by me
  2. Dodgydave
    Jun 22, 2012
    5,163
    774
    Can you draw it out put so we can visualise what you are doing?
  3. Bernard
    Aug 7, 2008
    4,242
    418
    12 drivers for hours?
    60 drivers for minuets ?
    60 LED's around rim for seconds ?
    Take hours, needs 12 control pins so to reduce count use 74HC154 16 step stepper requiring only 4 address pins. 74HC family uses 5 to 6V VDD, so use a buffer ( 74FCT244ATP, 8 stages or ULN family ) to drive LED's in parallel with a resistor for ea. LED ? 4- 74HC154's for min. & sec. 4 address lines & 4 control lines for ?
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    There are many LED clock schematics on the innergoogle, and some of them are very similar to your project.
    ak
  5. FroceMaster
    Jan 28, 2012
    402
    oki, can you give me an example ?
  6. absf
    Dec 29, 2010
    1,493
    374
    I built this one a couple months ago and it's cool...:)
    Allen
  7. FroceMaster
    Jan 28, 2012
    402
    More like this,
    Where the time on this is "15:10:00" "Watch.png"
    The 'Problem" is that i would have 180 outputs to control.
    Any hint on doing that ?
    i have planes to do it like this "first lay.png"
    i know i miss a lot on the controls, but i think you get the big Picture on how..
  8. hp1729
    Nov 23, 2015
    2,105
    235
    24 hour clock? 15:10 is 3:10 PM.
    I gave some thought to such clocks but simplified it down to just 12 positions. 12:00, 12:05, 12:10 etc. A lot fewer LEDs.
  9. blocco a spirale
    Jun 18, 2008
    1,461
    370
    It's not really a big problem just very time consuming to build, you can do it all with shift registers, a bit of logic and a 1 second timebase, the PIC is not necessary. Divide the clock into 3 concentric rings with hours in the middle (12 outputs), then minutes (60 outputs), then seconds (60 outputs). If you use open-collector outputs (which you probably will) and "steering" diodes, you can overlap the "hands".
