Hello folks ive just purchased a 1 farad cap to make a battery tab welder. im planning to use a automotive glow plug relay rated at 120A on the disharge side. -ve will be connected to cap and then to output electrode, the positive side on both the supply to the cap and the +ouput electrode will be switched, hope this makes sense. Hopefully completing soon will submit image and results.The primary of the glow plug relay will be switched by trigger switch attached to electrode(insulated of course), this switch will also switch primary feed to cap +ve either directly or by means of another 12v relay.
Supply via voltage reg set to 13.8v. (Lm317T)
Planning not to use Scr as these can be expensive for high current versions, and they have tendency to fail with this sort of set up.
Can anyone offer any further advice?
