I have a few devices that I would like to run on household current, but they are battery powered devices.
Example: I have a battery powered Air Compressor with weak batteries. They cost too much to replace for what the unit is worth.
When I have it hooked up, and it is charging, it won't start up. It will only start after I charge it for awhile, and unplug the charger from the wall, etc.
Is there a way I can wire this up to run off of the 110, when the charger is plugged in?
Same question for Battery Powered drills, etc.
Thanks,
Gary
Thanks,
Gary
