This is my first post on this forum, I'm new to electronics but eager to learn
I have a big interest in audio and I want to make an amplifier for a 8ohm 0.5W speaker I have lying around, if I connect it directly to the audio jack of my phone
it barely makes any sound. So after some research I discovered I need an amplifier IC. So after hours of digging around on old pcb's I found a chip. An LF 351N. The datasheet gives says it's an op amp, but for circuitry I could only find some exemplary uses on the datasheet. I found a circuit for an inverted amp, will an inverted amp be suitable for listening to music? Anyway, I'm looking for a cicruit for this chip to make an amplifier. All help is appreciated.
