Making a 60 mhz Ref
Discussion in 'General Electronics Chat' started by Dr.killjoy, May 14, 2016.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I working on calibrating a oscilloscop.. I need a calibrated 60 Mhz and can this be made with basic parts and skills ???
    Could you use a gps reference ???
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Sorry I meant 60 Mhz and I am trying to output a sine or square wave to check the calibration of my Tek 2215.. The scopes max is 60 Mhz and it doesn't have to be 60Mhz but hopefully pretty close..
  4. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    You need many frequencies to calibrate a scope. A time mark generator is usually used.
  6. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I have a DDS and signal generator and plus I picked up a Heathkit IG-4504 scope calibrator..
  7. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    The german site box73.de has a kit to make an IQ-DDS generator:
    The SMD parts are already mounted.
    Bertus
  8. dl324
    Mar 30, 2015
    3,376
    651
    A time mark generator makes it easier to calibrate the timebase; it's listed as required equipment in the 2215A service manual.
  9. GopherT
    Nov 23, 2012
    6,303
    4,021
    What kind of project do you plan to work on that will require such a precisely calibrated scope?
  10. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I should probably explain myself a little clearer.. This scope turned on when I got it and never showed a signal when terminated cause the input resistors where shot.. After alot of help form the yahoo Tektronics group I figured a couple more issues and possible upgrades to the trigger system.. I just trying to make sure the scope is use able and somewhat calibrated ..
  11. Kermit2
    Feb 5, 2010
    3,845
    963
    XTEST.gif Get some crystals and build a little osc to plug them into...
    Check your scope at three or more freq
  12. kubeek
    Sep 20, 2005
    4,687
    805
    Do you want to calibrate the time base, or the amplitude at that frequency? Note that the bandwidth is usually up to the -3dB point.
  13. RichardO
    May 4, 2013
    1,335
    429
    You are better off verifying the bandwidth by using a squarewave. This will also show if there is overshoot or ringing in the vertical amp.
    The relationship of bandwidth to risetime is 0.35/risetime. For example, a 10 MHz scope has a 35 ns risetime. The risetime of the squarewave must be much less than the risetime of the scope for this to be accurate.
