Hi there, I am doing my best looking up things on the internet, but I am getting a little lost in some of the simple matters.
Currently I have in my possession, around 50 of these blighters. Failed ebay seller
http://www.ebay.co.uk/itm/Solar-Pan...068782?hash=item19f36b292e:g:AssAAOSwZd1VdrCj
Specification:
Solar panel power: 7V, 1.12W
Solar panel size: 11*11cm
Pump power: 7V, 160MA
Cable lenght: about 320cm
Life time: ≥ 20000hours
Please can you help me in the following.
I am looking to create (firstly) a 5v 1Ah array.
I will need a 5v regulator to bring down the 7V (I get ~8 some days 7.8v) to 5.
If I have a 5v 2Ah battery, will this cause issues? Or would it take twice as long to charge? Does this also mean that the array would last twice as long powering the 5V 1Ah . (Presuming the battery was at full strength)
I will need to use more than one panel in parallel to be able to supply the ampere needed
I will need some form of battery bank / to hold the charge
I will need a diode to stop any power going in the wrong direction (put at the + of the solar panel?)
I will upload some pictures of the solar panel tonight as I would also like to ask, there is an IC inside the panel with a cap, should I bypass this, and take the power from the solar panel directly, or should I use the IC that is inside?
Again I will upload the images tonight and I thank any one that is willing to help a rookie try to learn.
Specification:
