Making a 1-bit adder using a Mux
Discussion in 'Homework Help' started by jwatts, Mar 10, 2008.
  1. jwatts
    Mar 10, 2008
    So I have a homework problem where I have to make a 1 bit adder using a 4:1 Mux. Anyone have any ideas on this?
  2. jwatts
    Mar 10, 2008
    no ideas for this problem?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Let's have a quick review.
    A one-bit adder has 2 input bits and one result bit. The two input bits represent one of four possible conditions.
    A 4:1 multiplexer has four inputs and one output and TWO select bits. The two select bits select one of four possible constants (either 0 or 1) which can be routed to the output.
    Are you starting to get the idea?
  4. jwatts
    Mar 10, 2008
    Yeah I got it figured out. Thanks
