making a 0.01 mH
Discussion in 'The Projects Forum' started by tune, Nov 6, 2009.
  1. tune
    Oct 30, 2009
    i intend to use a o.o1 mH for my oscillator circuit which transmits at 160.7 MHz what are the parameters which l need to consider
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  3. Ron H
    Apr 14, 2005
    7,050
    657
    I hope this is used as an RF choke. If it is in the tank (resonant) circuit, the value is much too high.
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    He he~! Yeah, I hope he means uH too.!
    Eric
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, even as an RF choke, it's too high. It would be operating well above self-resonance.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Get a cheap Bic pen. Take the ink tube out using a pair of pliers or dikes.
    These pen barrels measure 0.330" in diameter.
    Wind 28 gauge magnet wire on the pen barrel in a single layer, tightly spaced, 18 turns. Apply a little Superglue or the like to keep it from spreading apart/opening up. Then on top of those 18 turns, wind another 17 turns. The finished coil should be 0.230" long, and measure about 9.98uH. You can leave the pen barrel inside the inductor.
  7. steveb
    Jul 3, 2008
    2,433
    469
    Can you double check your math? I get about 1 uH for that design. One of us lost a decimal place.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, you did. ;)
    I've just checked using a few online multilayer air coil calculators. Seems that there is a difference in opinion between myself and several calculators about the physical diameter of AWG 28 magnet wire; all somewhat different, likely due to the thickness of insulation. This of course affects the calculation results. One site thought 37 turns were needed, another calculated 39 turns. I don't happen to have any AWG 28 magnet wire on hand.
    Of course, different gauge magnet wire could be substituted, or a different size core, but the turns/layers would have to be re-calculated.
  9. steveb
    Jul 3, 2008
    2,433
    469
    Yep, I did. Sorry about that. I used a metric version of the Wheeler formula and must have screwed up the inch to meter conversions somehow. That coil size struck me as being too small for 10 uH, but my intuition is just wrong.
  10. Xantor123
    Nov 1, 2009
    If it's for the tank circuit of a 160MHz osc, 0.01uH would be more likely, let's say 4-5 spaced windings of silver coated copper wire, airform.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Actually, for a 0.01uH (10nH) inductor, 1 turn of AWG 22 around an 0.200" form would do it.
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Wheeler's formula won't work for multilayer coils, which is what I was describing (a 2-layer coil). Wheeler's is pretty handy for single-layer coils though.
  13. steveb
    Jul 3, 2008
    2,433
    469
    It provides a reasonably estimate for a 2 layer coil. In this case we calculate about 8.6 uH. I was just trying to get an order of magnitude estimate to check my intuition that the coil seemed too small.
    Of course, both my intuition and my calculation were wrong. I usually make mistakes in pairs, which really gets me into some trouble. :)
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I hear you about the mistakes in pairs. ;)
    Fiddling around a bit more with my spreadsheet, two turns of AWG 24 wire around a 0.070" form (a #50 drill bit would be perfect) works out to 9.98nH.
