hi there I need some help with some electrical circuitry.
I volunteer each year for a local pantomime and we have made a huge prop caridge for Cinderella.
It is made out of MDF and we want the wheels to look like they are going round. I have a big bag of LED's (spec below) and have an idea in mind.
Imaging a curricular piece of MDF (a wheel) with hole drilled out of them and 48 LED's in the holes. what I am wanting to do is have the LED's lit-up and every 3rd not lit and then all the LED's that are not lit to move up 1 giving the effect the the wheel is moving?
i also want to run this on batteries. up to 12v i guess i could go
how could I do this.
here is the spec for the led.....
WHITE 5mm LEDS
INTENSITY 900012000mcd
FORWARD VOLTAGE 3.03.4v
FORWARD CURRENT 20m/a
DOMI WAVELENGTH nm
HOUSING WATER CLEAR
VIEWING ANGLE 20 degrees
thank you so much for reading
WHITE 5mm LEDS
DOMI WAVELENGTH nm
HOUSING WATER CLEAR
