Make program in pascal for ARM7, is possible ?
Discussion in 'Embedded Systems and Microcontrollers' started by bernt, Oct 16, 2010.
  1. bernt
    Oct 16, 2010
    5
    Hi... Have you heard that a pascal compiler can create programs for ARM7 ? This is for a hobby project with a LPC2148, and i won't learn C or others...
    Thanks.
  2. retched
    Dec 5, 2009
    5,201
    313
    Yes. Take your pick.
    Google ARM pascal
    and choose which one you wish to use.
    [ed]
    Ok, I got a little more interested in this. I have a development board called the EasyPIC6 made by MikroElektronika
    http://www.mikroe.com
    They also make an EasyARM dev board.
    Point: They make a C, BASIC, and PASCAL compiler for many microControllers, so I checked to see if they made PASCAL for ARM...
    Well it doesn't appear so. ;)
    BUT, http://www.freepascal.org/ has a free PASCAL compiler for just about everything out there.
    So there ya go.
    [/ed]
  3. bernt
    Oct 16, 2010
    5
    Hi retched and thaks for your reply.
    I know about all products of MikroElctronika, beacause i already use my EasyPIC5 with MikroPascal PRO for PIC.:)
    MikroE have not a pascal compiler for ARM...
    I know as well Freepascal... it's maybe a good solution ?.... maybe...
    Thaks
    Regards
  4. retched
    Dec 5, 2009
    5,201
    313
    Freepascal is worth a try!
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    Another approach could be to find a Pascal to C translator (search for "pascal to c"). Then you could write in Pascal and use a C compiler.
  6. bernt
    Oct 16, 2010
    5
    Hi! a P2C converter is a good tool to translate, for example, this code: if H = true then Z := Z + 1;... but for a big algorithm (> 1000 line), with many loops (while, repeat/until), pointer and specifics types... it's more and more difficult to do a correct translation...
  7. bernt
    Oct 16, 2010
    5
    Hi!
    For the question "Make program in pascal for ARM7, is possible ?", the response is YES !
    Look at this good tool form this web site: http://rentcom-embed.jimdo.com/
    This is a complete IDE/Compiler for ARM7, with many libraries...
    Regards
    Bernt
  8. bernt
    Oct 16, 2010
    5
  9. retched
    Dec 5, 2009
    5,201
    313
    Honestly, you are the only person to bring up pascal in the last year or so..
    I would see if the product has a following, and a forum.
    There is likely where you will get good info on it.
    I honestly would not mess with pascal.. I havent since TurboPascal in the early 90's
    Im not saying you shouldn't, I have spent a lot of time "forgetting" pascal to learn 'C' and embedded basic, so I have my plate full... Same reason, i guess, that you will not learn C..
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I used to love Pascal, just made more sense than C to me. I remember learning it on Alice Pascal (now free). Doubt it'll ever be more than a niche language for microcontrollers.
  11. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    As it is a french product you will probably not find many people who have tested it.
    You can download a trailversion I saw on the website.
    I do not know if there are limitations with it.
    Bertus
