make or break
Discussion in 'General Electronics Chat' started by DexterMccoy, Apr 10, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    I can't the difference between a make or break rotary switch VS a break to make rotary switch
    What is the difference?
    I can't the difference between a make or break relay VS a break or make relay switch
    How can you tell the differences?
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    In rotary switches you have to state the mode or type, there can exist many configurations, functions etc.
    Often the rotary switch state is make before break, or break before make, (next contact).
    In a relay, the contact condition or state at rest or non-powered is the normal declared condition.
    Max.
  3. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    Surely on a relay it depends on how you have wired it? as one contact with no power will have contact and one wont. Slightly odd question
  4. DexterMccoy
    Feb 19, 2014
    429
    How can you tell which rotary switch you have when you're clicking it in a circuit? how can you tell if it's a make before break or break before make?
    So how can you tell if a relay is a make before break or break before make?
  5. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    Turn the power off
  6. DexterMccoy
    Feb 19, 2014
    429
    I still don't understand the difference between make before break or break before make
    How can you tell the difference, what tests can I do to know what type of switch it is?
  7. w2aew
    Member
    Jan 3, 2012
    219
    64
    Make before break connects the next circuit before disconnecting the current circuit. Break before make disconnects the current circuit before connecting the next circuit. See http://www.allaboutcircuits.com/vol_4/chpt_4/3.html
  8. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Use your imagination!
    When you turn the switch and if the next contact is made before the present one releases contact it is make before break, if the contact is broken between one section and the next it is break before make.
    Use a meter!
    Max.
  9. DexterMccoy
    Feb 19, 2014
    429
    Why would you want a circuit to do a Make before Break switching?
    Why would you want a circuit to do a break before make switching?
    RULE OF THUMBS
    When would you want a circuit to have Make before Break switching?
    When would you want a circuit to have Break before Make switching?
    What are some common examples of using Make before Break switching?
    What are some common examples of using Break before make switching?
  10. bance
    Member
    Aug 11, 2012
    315
    34
    How long is a piece of string?
    spinnaker and shortbus like this.
  11. t06afre
    May 11, 2009
    5,939
    1,222
  12. ErnieM
    Apr 24, 2011
    7,436
    1,626
    That varies with how high up is.
    I have never seen "make before break" used with relays.
    I can't think of any uses besides switches but I would not rule it out.
    As far as testing, make before break WILL short two outputs together during the change. That is detectable with a fast ohmmeter, or a light bulb, or a...
  13. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    Yes but what's a light bulb?
    what does it do?
    Why would you use one?
    When would you use a light bulb instead of say a strip light?
    How many watts does the light bulb have to be?
    How can I tell if I need to use a light bulb or say a Led?
    Why did they design a light bulb to give out light?
    Why was is it a curly coil and not straight?
    What did the guy who invented the Light bulb have for his lunch?
    How fast does the Ohm meter need to be?
    Can I use a analog one?
    What button on my DMM do I use?
    I have looked on google and cant find a A...... Whats it for?
    When would you use A a....?
    Why use A a.... instead of a light bulb?
    There I think that just about covers the next set of question's
    shortbus likes this.
  14. DexterMccoy
    Feb 19, 2014
    429
    Why would you want to short out to outputs during a change?
    I thought shorting out to outputs together can damage both outputs channels when shorting them out together
  15. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I'm assuming for now that you actually want to learn something and are not just trolling. Because most of your threads DO look like trolling.
    Maybe if you tell us your age and level of electronics schooling or experience we can tailor the answers to your knowlege level and make this go easier.
    Regarding make before break, it is important sometimes to make sure the signal is not cut off during the switching.
    Make before break rotary switches are often used in audio equipment to select different audio sources. If the switch breaks, there is NO signal at all for a brief period which can cause a loud unpleasant POP sound. So a make before break switch is used instead.
    Depending on what is being switched, it might be best to break first, then make. Or in other applications it might be better to make before breaking.
    Most cheap hobby type rotary switches are make before break, as one of the most common traditional uses was in audio switching. (And it probably makes the switches easier and cheaper to construct).
    absf and shortbus like this.
  16. BillB3857
    Feb 28, 2009
    2,402
    348
    I should have looked at the poster name before reading the question. Simple answer as to WHY, ... The circuit demands it for proper operation. Some inputs simply don't like open circuit inputs so the Make Before Break is in order. Some circuits demand that the two options must maintain isolation between them, therefore, the Beak Before Make option is required. All components are selected to 1. make the overall function work properly, 2. help the brother-in-law sell parts.
  17. MrChips
    Oct 2, 2009
    12,635
    3,453
    Another example of make-before-brake rotary switching is in resistance boxes or ammeter range switch.
    Suppose you want to switch an ammeter to a different range setting or you want to select a different resistor that is in a series circuit. You may want to maintain a continuous current within the circuit.
    absf likes this.
  18. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Forsooth methinks this is all a wind up. :(
    All of these recent questions can be answered by a simple Google.:rolleyes:
    Max.
  19. t06afre
    May 11, 2009
    5,939
    1,222
    If DexterMccoy fail to answer this question in a proper way. I will add him to my virtual ignore list. It is kind of make or break for him this.
    ErnieM, THE_RB, absf and 4 others like this.
  20. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    My guess mid 20's say 27-28
    Got lucky at college and somehow just scraped a pass, blagged somewhere around 20 jobs in last 4-5 years. Knows as much about electronics as I do girls!
Thread Status:
