hEY ALL OF YOU GUYS.....i had been given a project in which i want to make a contant 5V DC power supply....help me and give me full details or a good link about it for help...this is my first project......thnk you.,...
That will dissipate (waste) 2 Watts as heat when the load is 500mA.Hi Zeeshan,
Here's a diagram on a pcb you can use for your 5v supply
A switching power supply dissipates fractions of a watt of heat at 500mA load.
This guy wanted to build a project. if he use a ready made smp it wont be what he asked for as far as i concern. So, he can just add a heat-sink to the regulator. Change the 9vac input to a 6vac transformer.
That's a valid position. However I'm personally thankful that when I come here with preconceived notions of what I want, the smart people here challenge those notions and remind me of much simpler solutions, if those exist. That's what friends are for, to challenge us before we do something silly. The OP could very easily find a circuit for himself if all he wants is a circuit. Engaging with the living, breathing people here implies a need for a bit more, the wisdom of one's friends.This guy wanted to build a project. if he use a ready made smp it wont be what he asked for as far as i concern
Hey wayneh, thanks for the lecture you just gave me. I'LL remind myself of it the next time i post a reply.That's a valid position. However I'm personally thankful that when I come here with preconceived notions of what I want, the smart people here challenge those notions and remind me of much simpler solutions, if those exist. That's what friends are for, to challenge us before we do something silly. The OP could very easily find a circuit for himself if all he wants is a circuit. Engaging with the living, breathing people here implies a need for a bit more, the wisdom of one's friends.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jake Hertz
