It's that time of summer where haying season is about to start for us and i need to take my tote tanks and transfer pump I use for picking up used oil off my flatbed truck so given that I figured I would do a trip to my local shops I get used oil from and see what they had before I pulled everything off for hay hauling.
First place I stopped by had some but was already claimed by another guy. No problem.
Second place had 1000 gallons two days ago for me but lost my phone number and couldn't remember my last name so they let another guy take it but they did say to hit them up around October and they will likely have another 1000 I can take.
Last stop for the day was a place I never went to before but was recommended by the other guys. Sure enough, they had 400 gallons ready to go! As I was transferring their used oil the manager came out and asked me if I wanted anymore so of course, I said, "yes I will take anything you got!
He told me to meet him at their bulk station on the edge of town when I was done and there should be at least 8- 10 barrels I could take and maybe more.
So I roll up and he gets there about 5 minutes later. He shows me their bulk barrel collection and says that at leat 8 or 10 of them are full or nearly full and many others have odds amount in.Then asks if I take old diesel fuel as well. I said sure! I take anything that burns!
Great! He says. The EPA just made them recondition their whole bulk tank system (~$50K job) and they had around 200 gallons of stuff they pumped out of the bottom of the tanks and lines they were not allowed to resell.
Around 100 - 150 of it was red died with a bit of clear road fuel mixed in in barrels and the rest was, around the same mix, that had been dumped into an old tote tank that had around 50 gallons of used oil in it.
All said and done I ended up with between 2o0 and 250 gallons of mixed diesel with ~ 50 gallons of used oil blended in now. I'm figuring I will run it through a 10-micron filter and it should make for good mystery mix tractor diesel fuel!
On top of it all that they have a pile of mixed scrap metal sitting on site they want gone too before their next EPA follow up visit.
I was told I could have anything I wanted or the whole pile. One item is a ~18" wide by ~20' long heavy stainless steel conveyor frame that probably weighs several hundred pounds. Plus there are also several large commercial air conditioning compressors of which from my scrapping experience I would say have around 10 - 20 pounds of copper in each.
Also, there is several hundred pounds of aluminum and a good ton or better of heavy cast and misc iron framing and piping too including a bunch of heavy brass valves and fittings that came off their bulk tank rebuild job!
It was a good day. Granted for a business (or someone like HP) none of this even adds up to decent walking around money so that's probably why it was given to some poor schmuck like me. They can get it to disappear out the back door no questions asked saving them the expense of paying to get rid of it plus filing paperwork to say where it went.
