Maintain v/f ratio in pic microcontroller output
Discussion in 'General Electronics Chat' started by innovetion, Feb 3, 2016.
  1. innovetion
    Oct 16, 2015
    I am using PIC18f4550. My aim is to control AC induction motor. For that I have generated required PWM pulses for required frequencies. But I need to maintain V/F ratio at the output. Which I am unable to do.
    Please suggest me.
  2. crutschow
    Mar 14, 2008
    13,487
    3,371
    The PMW modulation frequency determines the AC frequency applied to the motor, and the PWM duty-cycle along with the PWM carrier voltage determines the AC voltage applied to the motor.
    So from the modulation frequency you calculate the needed duty-cycle to get the desired motor voltage for the PWM carrier voltage you are using.
    innovetion likes this.
  3. innovetion
    Oct 16, 2015
    Thanks crutschow.
    Can you please explain briefly ?
  4. dannyf
    Sep 13, 2015
    2,196
    417
    Change the period register and maintain 50 percent duty cycle.
    Better use a v/f converter or a pic with NCO.
    If the frequency isn't too fast, consider dds in software.
