main switch
Discussion in 'The Projects Forum' started by mhe0312, Jun 26, 2013.
  1. mhe0312
    Nov 27, 2012
    9
    I want to ask if what are the components of main switch? is it possible to make your own simple main switch?is there available schematic diagram for this?thanks and more power!
  2. MrChips
    Oct 2, 2009
    12,642
    3,457
    What is main switch?
  3. mhe0312
    Nov 27, 2012
    9
    should i say the main source of electrcity or the circuit breaker?
  4. mhe0312
    Nov 27, 2012
    9
    main switch that turns the power off to the whole of the electrical installation.
  5. MrChips
    Oct 2, 2009
    12,642
    3,457
    I go to my local hardware store and buy a circuit breaker or something called a knife switch.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Circuit breakers and fuses are safety devices; they need to be carefully engineered and thoroughly tested under laboratory conditions to ensure their proper and safe functioning.
    If improperly designed/constructed, a fire and/or plasma fireball may result, the latter being extremely dangerous.
    For your (and others) safety, please do not attempt to make your own circuit breakers, switches or fuses, nor attempt to repair faulty commercial circuit breakers/switches.
    absf, wayneh and MrChips like this.
