I thought NZ had the same as Australia which is a 240v single phase and neutral I believe?What is the safest way to detect main? (120/240) I need to be able to detect if main is available, what is the safest way to do this? Thanks guys!
I like this non-intrusive detection, now I need to find out how a voltage detector pen works. Thanks for the info.Buy an electrician's voltage detector pen for $10 at Home Depot.
We only have 240V, but I added 120V to make it a more general question.I don't even know if you have 120/240V in NZ.
The info need to be readable by a MCU, I am detecting main fail to sound alarm.Whole lot of guessing going on with no application specified.
Yes, this is part of my power supply. No the current supply does not have a power good output. It only have two outputs, one for charging a battery, one for a load. When main is available, it charges the battery and power the load. When main is gone, it powers the load through the battery, and it also do low voltage cutoff.I am guessing this has to do with the power supply? Did the current power supply not have a power good output?
Safest - Just get the smallest transformer you can find that outputs 5 volts. You can connect that directly to your logic. No need to scale anything after.
You are absolutely correct.I thought NZ had the same as Australia which is a 240v single phase and neutral I believe?
Max.
by Aaron Carman
by Jake Hertz
by Duane Benson
by Duane Benson
