Mailbox light on/off with reset button
Discussion in 'The Projects Forum' started by PurGe, Jul 10, 2013.
  1. PurGe
    Jul 10, 2013
    Hello world :)
    I am researching an idea that i had, for a simple mailbox notifier, which would turn on a light when mail has been received. However, it appears to be less simple than i would have thought. As with almost everything else :)
    Anyway, i was wondering if any of you knew if it is possible to use a magnetic switch to turn a light on, but not off, without the use of an expensive board like Arduino.
    In short, i want to turn a light on using a switch, but only off using another switch. Can that be done in an elegant and simple way?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    It can be done without electronics using a mechanical relay, wired to function as a latching relay.
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    I'd consider a light detector for your trigger. I think you could use a comparator to latch - requiring a manual reset - once the light detector triggers. What sort of light are you planning on, and how will you power it?
