Magnifying Video Camera for drilling?
Discussion in 'General Electronics Chat' started by spinnaker, Dec 21, 2015.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,074
    1,176
    Has anyone mounted one of those video pens to aid in drilling PCBs?
    If I do not go with a CNC, the press I am considering is this.
    http://www.micromark.com/microlux-3-speed-mini-drill-press,7797.html
    I was thinking if I could mount one of those magnifying pens somehow, it would make the job of drilling PCBs a lot easier.
    http://www.ebay.com/itm/600X-2MP-6-...341857?hash=item2c9bbbdf21:g:HPQAAOSw~OdVaevk
    It would probably be best if I can get it inside that housing as close to the chuck as possible. But with that stand it just might work too.
    Any ideas?
  2. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    For me, I would think that 600X is too much magnification for drilling a PCB. Higher mag generally means a smaller focal length. You can see the effect with just a jeweler's loupe at only 7 or 10X magnification. Your 600X microscope wouldn't even provide you a clear view until it was almost touching the PCB. I like your idea of adding magnification, though. I use a scroll saw on wood and need to cut smooth curved lines to make the scroll patterns. I found a lighted magnifying glass at Woodcraft that fit the bill. It's only 10X, but I can split a sharp pencil line in half which I believe is enough accuracy for drilling PCB's, about 0.002".
  3. BReeves
    Member
    Nov 24, 2012
    412
    64
    shortbus likes this.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
  5. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Thanks for the tip. I would hope those magnfiers are adjustable but your advice will be helpful in confirming that.
  6. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Thanks for that information. I saw those before. Thought they looked similar. There are a number of them under different names. This might be swaying me back to proxxon.
  7. GopherT
    Nov 23, 2012
    6,309
    4,029
    you might try a macro or zoom lens for a smart phone and then you have the monitor and camera in a compact position that will fit near your drill. Some lenses are only $15 and likely good enough for drilling.
    I have one that I use for close-up surfaces at work - bought it at Five-Below for $5.
  8. shortbus
    Sep 30, 2009
    4,095
    1,681
    I would mount a laser pen under the drill table, inline with the drill bit. That way when the small spot in the PCB 'island' is in the correct position you can tell.
