magnetic wire guage ratio between primary and seconday windings
Discussion in 'General Electronics Chat' started by adeel, Jun 28, 2008.
  1. adeel
    Jun 28, 2008
    16
    hi ,
    Friends i need ur help i want to build a transformer to step down voltage i have 1.5*2 (inch) core and i want to make 25 amp 12 volts transformer but i am surprised i have no guage ratios i have turn ratio formula but not the guage ratio. Description is here
    220 volts for primary 50/60 hz
    12 volts for seconday
    if u know guage ratio for primary and secondary (like 22 or 12) please give me the formula thanks .
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. The Electrician
    Oct 9, 2007
    2,300
    335
    A good working rule of thumb is to make the current density in each winding the same.
    In other words, the current divided by the cross sectional area of the winding should be the same for both the primary and the secondary. You will have to select primary and secondary wire gauges such that the winding window is as full as possible while maintaining equal current density in the two windings.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Transformer voltage ratios go by turns in primary/turns in secondary. The wire gauges are important, but the core structure is the determining factor in the amount of power the transformer can handle. Winding the primary and secondary with heavier gauge wire will not increase power handling.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Sorry to dissapoint you, but with that size of transformer core at 50/60Hz, you will be lucky to get over 2 Amperes of current at 12v. You need a much larger core, more like 5" * 6" or thereabouts (this is a "ballpark" guess.)
    The wire size is determined by the amount of current expected in the circuit.
    Here is a website that has a table of wire gauge vs current:
    http://www.powerstream.com/Wire_Size.htm
    You can use "chassis current" for your transformer. The smallest size you could use for a 25A secondary carrying 25 Amperes would then be AWG 15.
    Your primary side will likely have around 1.5-1.6A of current. The smallest size you could use would then be AWG 27.
