Magnetic to Piezo
Discussion in 'Electronics Resources' started by Nanophotonics, Feb 1, 2010.
  1. Nanophotonics
    Thread Starter Active Member
    Apr 2, 2009
    365
    I'm currently working on an audio project and one of the various tasks is to find out a way of making a magnetic pickup to sound like a piezoelectric one. I couldn't find the relevant information on the web. If you know any links/advice at all, please let me know.
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Nanophotonics
    Apr 2, 2009
    365
    Thanks for the link.
    Yes, I meant it literally. I'm thinking of using an electronic circuitry that will adjust the magnetic pickup's response and make it as close as a piezo one. Would a proper filter do the job?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Skipping over the completely differing mechanisms of producing the electrical outputs, yes, sort of.
    You need to determine the magnetic pickup type - moving magnet or moving coil - make a preamp to accommodate the low signal level, and apply a RIAA network ( http://www.glass-ware.com/audiogadgets/AG_RIAA_Eq_Networks_Design.html ) to adjust the frequency responses over several areas to the audio band to remove the funny non-linearities on the record due to the funny characteristics of the cutter head.
    After that, you will have an output with similar levels to that of a ceramic cartridge. The last bit - obtaining that public telephone-like quality to the reproduction - may only be possible with an old 45 RPM record.
  5. Nanophotonics
    Apr 2, 2009
    365
    Thanks for the reply. It makes sense to me. Actually, it's for a guitar pickup, more precisely a humbucker.
  6. rjenkins
    Nov 6, 2005
    1,015
    69
    I don't know if it's so much the pickups 'sound' different, as the sound they detect is from different sources?
    A magnetic pickup is directly detecting the movement of the strings, where a piezo pickup is (I think) normally an add-on for an acoustic guitar and is detecting the soundboard vibration with all the extra resonances that gives.
    If that's what you are trying to do, then I would guess what you want is something along the lines of a reverb or chorus type effect pedal to give additional depth to the sound.
    (I've built and wired electric guitars and effects, but I know absolutely nothing about acoustic guitars & their pickups etc., so apologies if I'm wrong).
  7. Nanophotonics
    Apr 2, 2009
    365
    Thanks for the post. That is correct. However, I'm trying to use only a magnetic pickup, feed its output signal into an electronic circuit such that upon listening to the resulting sound produced via a loudspeaker, you would think that only a piezoelectric pickup was used.
  8. Darren Holdstock
    Feb 10, 2009
    262
    11
    Not sure why you'd want to do this, but if you must: Neuter the bass and introduce horrendous peaks and troughs into the remaining frequency response, and if you can, introduce some unpleasant ringing. That's your piezo sound right there. If you can find a datasheet for a guitar piezo pickup then the frequency response graph would be a good starting point.
    Piezos are normally used for augmenting a soundhole mic on an acoustic guitar; on their own they sound thin and nasty.
    This reminds me of respected ex-colleague Allan Bradford who once designed the fantastic "CD Spoiler" for ETI magazine. Its purpose was to make a CD player sound like an old Dansette record player, so it used a noisy, distorting amplifier IC, mixed it down to mono, and thanks to the unique "flabby earthing" system, introduced lots of mains hum. For best results he recommended placing the finished circuit inside a toaster.
    Allan's circuit was meant as a joke for the April issue, but I was quite serious in my first paragraph above, that really is why piezos sound like they do. It won't be an easy task at all to duplicate that frequency response as it looks like the Himalayas on a bad hair day. If you've got access to studio equipment, then you could try playing around with a parametric equaliser, as some of those piezo spikes have a high Q, hence the tiresome resonances.
  9. Nanophotonics
    Apr 2, 2009
    365
  10. Nanophotonics
    Apr 2, 2009
    365
    Anyone knows a typical single supply opamp I could use to design a Sallen-Key 2nd-Order Active Low-Pass Filter for this application? I will be using a 9 V battery, but adjustments can be made if lower voltage levels are required.
    I've got a few options, but please suggest any better solutions you may have.
    LMC6035
    OPA341
    LMV321
  11. Nanophotonics
    Apr 2, 2009
    365
    I finally chose LM324.
