magnetic pulse
Discussion in 'The Projects Forum' started by d0ug, Sep 26, 2012.
  1. d0ug
    Sep 26, 2012
    10
    This is my first post but need help in making a magnetic pulser for healing. The project is to convert 110v AC to 300v DC to charge a 1000 uf 350volt capacitor and then discharge through a coil to produce a magnetic pulse. I have tried three or four different schematics with out success. I also tried voltage tripler and had the capacitors over heat and burn out. I need a fool proof system as I am no pro. in electronics so please make it simple.
  2. wayneh
    Sep 9, 2010
    12,394
    3,246
    How often does the coil pulse (ie. what's the frequency)? Do you have a field strength you are trying to achieve?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Wikipedia says that this Quack Stuff actually works!
  4. d0ug
    Sep 26, 2012
    10
    I am not interested in a frequency only manual controlled
  5. ErnieM
    Apr 24, 2011
    7,442
    1,628
    And you can't put something on the internet unless it's true.
    I read that. On the internet.
  6. wayneh
    Sep 9, 2010
    12,394
    3,246
    I'm pretty skeptical as well and have done zero research, but I do know that a friend of my wife's recently received some sort of "magnetic therapy" and has gone from being imminently suicidal to enjoying a major upswing in her life. It's just one anecdote and hardly convincing, but you'd never convince her that it didn't work.
    Also, I'd be far more skeptical if I hadn't recently had firsthand experience with micro current neural stimulation. I HAVE researched that, and seen results personally, and it's the real deal. It helps people that often have no alternative. Making the leap to a magnetic field having an effect similar to µA level currents, well that's not so far fetched IMHO.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    If the OP isn't an experienced electronics tech then I'd discourage them from experimenting with hazardous voltages.
  8. Sensacell
    Jun 19, 2012
    1,184
    277
    What is an "OP"?
  9. t06afre
    May 11, 2009
    5,939
    1,222
    OP=Original Poster. It means you address the thread starter
    Sensacell likes this.
  10. d0ug
    Sep 26, 2012
    10
    Please can I find help with this circuit if it works for health or not is not important. think this post has gotten off track
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Start with a transformer that converts 110 VAC to 215 VAC. Run that through a bridge rectifier to get about 300 Volts Peak on the 1000 uf 350 volt capacitor allowing for some voltage drop in the bridge rectifier. Now you can do what you want with it from that point. As you have already observed this kind of power switching can be hard on the components. When the capacitor discharges into the coil you basically have a short across your power supply. That is a problem. When you interrupt the circuit to let the capacitor charge up you will have a VERY large inductive kick. This is probably what is destroying your capacitors. You need to absorb this energy.
    d0ug likes this.
  12. Dodgydave
    Jun 22, 2012
    5,159
    772
  13. d0ug
    Sep 26, 2012
    10
    Thanks do you have any suggestions on this circuit to absorb the surge. How large a transformer would I need. could I use a small transformer and a resister after the bridge to slowly charge the capacitor. Any suggestions that would help.
  14. Kermit2
    Feb 5, 2010
    3,852
    968
    NOW we need more information. What is your pulse repetition rate? or what freq is the circuit operating at?
    A switch could be used to give you an alternate charging path and which isolates your power supply from the 'short' circuit created on discharge.
    if the freq is less than 5 or 10 k then a solid state relay might be ideal.
  15. d0ug
    Sep 26, 2012
    10
    The pulse rate is manual it can be fired when the capacitor is charged. How strong of a relay do I need to take the capacitor discharge
  16. Kermit2
    Feb 5, 2010
    3,852
    968
    You only need the relay to carry the current for charging up the cap. A suitable resistor can be selected based on the RC time constant, or just use ohms law and calculate a rate of flow that is lower than what the relay is rated for. 1 amp should be more than sufficient.
    The relay will be open when you discharge. Your switch should activate the relay while in the 'ready' position, and remove voltage when the switch is used to 'fire' the capacitor. A solid state relay will react faster than the mechanical/magnetic type, so you can repeatedly press the switch as fast as humanly possible and the relay will keep up.
    Don't get cheap on the relay or the switch(these are pretty much the only working parts)
    d0ug likes this.
  17. Kermit2
    Feb 5, 2010
    3,852
    968
    d0ug likes this.
  18. d0ug
    Sep 26, 2012
    10
    I finally finished the magnetic pulse generator thanks to everyone. It works great it cured my mother in law with a neck problem which she had for three days in two minuets and helped many others. The only problem with the unit is when it is used for a few minuets it quits and I have to wait a while before using it again. There is a big ark in the relay when I fire it
  19. wayneh
    Sep 9, 2010
    12,394
    3,246
    Thanks for posting back with your success,and congratulations scoring big points with your MIL. I don't see a schematic anywhere in this thread, so I'm very curious what your final build was. Could you post a schematic and/or photos of your build?
  20. KMoffett
    Dec 19, 2007
    2,584
    234
    This is why the thread got "off track". The voltages and currents involved are lethal. I don't think anyone here, at least those with experience, are willing to take a chance that you don't do something that you don't understand, and kill or injure yourself. Or worse, someone else.
    Ken
