Magnetic low voltage transformer
Discussion in 'General Electronics Chat' started by ecliptic, Sep 26, 2014.
  1. ecliptic
    Sep 26, 2014
    I've got a magnetic low voltage transformer (120V to 12V). The instruction book says that the transformer must be loaded at least 80% for proper operation. That's fine, but my mind wants to know why. I can understand overloading would be bad, but underloading? Why would too small of a load be a problem?
  2. wayneh
    Sep 9, 2010
    12,394
    3,246
    Depends what "proper" means. It may need that much load to pull the voltage down to ~12V. Could be up around 16V or more, unloaded. Otherwise, I'd say the wording makes no sense.
    #12 likes this.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Small wall-wart type transformers are designed to not start a fire if short-circuited (overloaded). This makes for lousy load regulation, so a unregulated DC power pack advertised as 12Vdc under rated load will shoot up to 18V unloaded...
  4. b1u3sf4n09
    Member
    May 23, 2014
    115
    14
    Do you have a mfr/part number for this transformer?
    If this is a split bobbin transformer with no auxiliary or safety circuitry, then I don't understand why there would be loading requirements.
