magnetic head signal
Discussion in 'General Electronics Chat' started by cosmin800, Aug 29, 2005.
  1. cosmin800
    Aug 29, 2005
    I am tring to work with an ADC and i have one problem, the adc cannot see the negative alternance of the signal from the head, how can i shift the signal so all the wave from the head to be on the positive edge?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Hi cosmin800,
    I think what you are going to need is a differential amplifier that is powered from your positive supply. That way your read-head will be connected up as a floating signal source.
    Can you post your present read-head interface circuit here?
    hgmjr
  3. Gorgon
    Aug 14, 2005
    113
    You could be lucky if the ADC in question can take a negative -ref input, but the best is for you to post the schematic here.
    TOK ;)
  4. nomurphy
    Aug 8, 2005
    567
    12
