Magnetic flux density in a core
Discussion in 'Homework Help' started by Lahm332, Oct 6, 2011.
  1. Lahm332
    Oct 5, 2011
    When we want to build a a machine with as great flux density as possible while avoiding excessive saturation in the core. What would be a reasonable maximum flux density for this core?
    If the slope of the diagram is approaching to zero, then it's the place where the saturation occurs. However, I have no idea to find a suitable value for this question. Could someone please tell me what approach I should use in order to find a reasonable maximum flux density for this core? Thx~
  2. crutschow
    Mar 14, 2008
    13,491
    3,372
    It depends upon the core material. The core material data sheet will list that information.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Simply stating that you "want to build a machine" doesn't give one much to consider. Depending on the type of machine you are considering there may be several factors which influence the choice of maximum flux density.
