Magnetic behavior of ferromagnetic materials
Discussion in 'Physics' started by i_nour, Feb 20, 2016.
  1. i_nour
    Nov 9, 2015
    29
    Why do ferromagnets have varying permeabilities?
  2. profbuxton
    Member
    Feb 21, 2014
    233
    68
    Different molecular composition!
    i_nour likes this.
  3. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    Depends on the magnetic moment of the individual atoms in the ferromagnetic material.
    Silicon-iron or steel is a common ferromagnetic material with the one of the highest permeabilities and it's used in transformers and motors.
    i_nour likes this.
  4. BR-549
    Sep 22, 2013
    2,178
    418
    Because of the strength of the magnetic field, the ferromagnetic object was under, when it cooled from a molten state to a solid state.
  5. profbuxton
    Member
    Feb 21, 2014
    233
    68
    As I said. Different molecular composition.. it has nothing to do with cooling in an applied magnetic field. That can be used to make magnets. But in reality most permanent magnets are made by applying a very strong magnetic field to suitable magnetic material via a high discharge current through a coil. The high remanence of the material ensures it retains the induced magnetism
    i_nour likes this.
  6. shortbus
    Sep 30, 2009
    4,092
    1,674
    Transformer and electric motor stator steels are not used in there "as melted" states. Doubtful that any ferrous metal is left in the as melted state. Transformer and stator steel goes through many different heat treating steps before being used.
  7. wayneh
    Sep 9, 2010
    12,379
    3,232
    But the question as posed was regarding magnets, not transformer steel. It's hard to guess what the TS was really asking.
  8. shortbus
    Sep 30, 2009
    4,092
    1,674
    And I was answering BR549 and Glen Holland.
  9. recklessrog
    Member
    May 23, 2013
    346
    102
    i_nour likes this.
