maglev (magnetic levitation ) prototype for graduation project
Discussion in 'The Projects Forum' started by ronan albert, Aug 31, 2014.
  1. ronan albert
    Aug 31, 2014
    i want ask guys if it possible to do controllable maglev train and what i need basically
  2. Lyncheese
    Jun 28, 2014
    22
    Of course its possible. Nothing is impossible as long as you're willing to build it.
    read this link :
    http://science.howstuffworks.com/transport/engines-equipment/maglev-train.htm
    And you will get the big idea to get started.
    It said that for this system you will need :
    • A large electrical power source
    • Metal coils lining a guideway or track
    • Large guidance magnets attached to the underside of the train
    In short, a lot of electromagnetics.
    Good luck !
  3. crutschow
    Mar 14, 2008
    13,475
    3,361
    Here's a maglev design that's totally passive.
    nsaspook likes this.
  4. nsaspook
    Aug 27, 2009
    3,009
    2,350
    That's a cool design. We use Halbach arrays to confine and focus ion beam surface charge on wafers for neutralization with a Xenon plasma. The problem with this method of levitation Earnshaws_theorem is that it requires relatively high motion (energy) to be stable in a simple configuration without mechanical constraint. To achieve stable levitation at 1 to 2 kilometers an hour must require some very strong magnets and a complex track coils but it should be possible to build a simple version using a fast moving 'car' with a cable constrain on the track.
    http://gcep.stanford.edu/pdfs/ChEHeXOTnf3dHH5qjYRXMA/09_Post_10_11_trans.pdf
