magic electromagnet problem
Discussion in 'The Projects Forum' started by dougalere, May 4, 2015.
  1. dougalere
    Mar 4, 2015
    128
    5
    hi.
    finally got round to 'finishing' this pick up /drop project, works well apart from the fact that the electromagnet does not release when the power is turned off due to residual magnetism.
    i have got it to release by desensitising the poles with a bit of insulting tape but this is not entirely ideal.
    i am thinking of reversing the coil polarity at release somehow?
    any suggestions appreciated.
    thank you
    dougal
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Post the schematic of the coil driver.
  3. dougalere
    Mar 4, 2015
    128
    5
    hi
    i have revised slightly, the coil is now at the collector,the base resistor has been replaced with a 1ok pot.
    IC2 is an op amp.
    thnk you
    doug
  4. dougalere
    Mar 4, 2015
    128
    5
    supply voltage is 4.5 volts, 9volt was found to be too high causing overheating
    L1 THE ELECTROMAGNET IS LABELLED as 1 henry, this is a typo.
    the transistor is a TIP 31
    current around 500 ma
  5. Ramussons
    May 3, 2013
    562
    92
    Try a 100 uF capacitor across the electromagnet. When the transistor cuts off, the resultant oscillation of the capacitor-inductance will demagnetise the electromagnet.
  6. MaxHeadRoom
    Jul 18, 2013
    10,857
    2,525
    This is how it is done in most commercial lift magnets, a short reverse shot releases any load that remains attached after a lift.
    Max.
  7. dougalere
    Mar 4, 2015
    128
    5
    thank you
    i think this is solved in a roundabout way, i am using this to pick up a small nut and bolt -the holding force was fairly close to the residual force, by turning up the holding force and using a heavier nut and bolt it works perfectly, so i guess im swamping the residual force.
  8. MaxHeadRoom
    Jul 18, 2013
    10,857
    2,525
    You are probably swamping the residual force by using a reverse polarity, but you may reach the point where the residual is now reversed which then returns to the same problem?
    Max.
