Macintosh LC power supply
Discussion in 'General Electronics Chat' started by tab a, Jan 22, 2015.
  1. tab a
    Jan 14, 2015
    10
    I suspect the power supply in my LC is bad. Before spending time/money fixing it, any reason I can't remove it and jumper in the +5, -5, and 12v supplies, using an Allied Al-A300 ATX supply I've got?
    Thanks.
  2. shteii01
    Feb 19, 2010
    3,507
    512
    Apple LC II?
  3. wayneh
    Sep 9, 2010
    12,391
    3,246
    A dead PRAM battery will keep it from booting, as I recall. I'd start with that. Remove the old one and see if another battery will get it going. You don't have to buy the fancy one - just get close to the nominal voltage to see if that's the issue.
  4. GopherT
    Nov 23, 2012
    6,319
    4,043
    Again, "An Apple II LC?" ! Really still working?
    Or is it a Liquid Chromatography system?
    Or a ...
  5. tab a
    Jan 14, 2015
    10
    It's an Apple LC (I, I presume). :)
    Already put in a good battery.
    Just want to see if it will boot, with a known, good, power supply.
    Thanks.
  6. wayneh
    Sep 9, 2010
    12,391
    3,246
  7. tab a
    Jan 14, 2015
    10
    No, I don't. :)
    There are NO Roman numerals after LC, so I presume it's the model BEFORE the LC II?
  8. wayneh
    Sep 9, 2010
    12,391
    3,246
    Ah, this one then?
    You do realize that, even if it works, it has negative value and you may have to pay someone to take it away? I think I have one in my basement.
  9. tab a
    Jan 14, 2015
    10
    No, again. ;)
    Check ebay. The entire systems, which I have, can go for quite a bit of money --to collectors, I assume.
  10. wayneh
    Sep 9, 2010
    12,391
    3,246
    I'll have to look into that. I've got several models from Apple IIe up to a G3 Mac. I'd love to turn them into ...anything... besides scrap.
