Mac Software
Discussion in 'Electronics Resources' started by MusicTech, Apr 8, 2008.
  1. MusicTech
    Thread Starter Active Member
    Apr 4, 2008
    144
    Anyone no where I can find good mac circuit simulation. Yeah, I am sorry. A mac user who is trying to be an engineer. Anyway, I have searched google pretty thoroughly and only found 2 downloadables, both of which did not work. Preferably if anyone knows of something with more visual interface than command line, that's great, if not that than SPICE, and if neither of those anything will do (I don't know many simulators, so there is probably something better than SPICE I don't know about),
    Thanks a lot
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    "Mac" and "engineer" doesn't go together well!
    The only package I'm aware of is MacSpice, and comments on MacRumours suggest that it is the best you are going to get. Looks like you might be better investing in a Windows license and running it (ideally) on its own partition or get Parallels and run it that way.
    My experience of using scientific and engineering software on a Mac is anything but good.
    Dave
  3. MusicTech
    Apr 4, 2008
    144
    I know, I should put windows on this. I am just so reluctant. I used windows for 14 years and never liked the interface, and then I finally go my own computer, a mac, and now it is hard to go back... I will try though, thanks
  4. MusicTech
    Apr 4, 2008
    144
    on the command line interface for SPICE, what is the first thing you must type, everytime I try to add a component it says not available in SPICE. maybe it is just a mac thing, but when a new project is started what are the first few commands you enter?
  5. gvenn
    Apr 23, 2008
    Try QUCS. I would install via macports. Not sure about the degree of spice support (if any), though. I'm being a little vague on this as you must be UNIX capable to install this package. Anyway seems to work pretty well.
  6. lostowl05661
    Member
    Apr 18, 2008
    28
    I just installed qucs and it is pretty slick. It has a drag and drop circuit designer, which is easier for me than writing text files for spice.
    It took me a couple of days to figure it out (mostly because I am a Linux user and don't really know how to relax and think Mac) and heres what I did:
    1) Install the latest version of Xcode for your OS. For 10.4, its Xcode 2.4. For 10.5, it's Xcode 3.
    2) Install X11 from the OS X dvds. Check online for directions.
    3) Install darwin ports. Note: From the down load page, there aren't actual directions. Search for the Installation instructions.
    4) Set your environment variables per the Darwin install instructions.
    5) Run the command line command to install qucs
    6) Open the xwindows terminal and run qucs
    Note: I had to let darwin ports install about a billion packages. It took about two hours. But, now, I happily downloading the tutorials and workbook to learn to use it.
    Good luck.
  7. lostowl05661
    Member
    Apr 18, 2008
    28
    Quel stupid. There is also a Mac OS port, qucs download page, near the bottom.
