M8/M12 connectors and screw terminal compatibility
Discussion in 'General Electronics Chat' started by AgedStudent, Nov 3, 2014.
  1. AgedStudent
    Nov 24, 2013
    7
    I am trying to put together a simple monitoring system using some ultrasonic proximity sensors. I have found some at the right price/switching speed etc., but the connector options are either M8 or M12.
    I need to attach them to a screw terminal block.
    My question is, can I remove the M8/12 connector to expose the bare wires that I can then screw into the terminal block or do I have to keep searching for sensors listed with bare wire connections?
    Any advice would be welcome.
    Kind regards
    Steve
  2. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi,
    I would say if you make a careful note of the colours of the wire associated with each pin number, a terminal block would be OK.
    E
    AgedStudent likes this.
  3. AgedStudent
    Nov 24, 2013
    7
    Fantastic
    Thanks for your help
    Steve
