[M68000] move.w (a0)+,(a1)+ causes crash!
Discussion in 'Programmer's Corner' started by oerg866, Apr 3, 2009.
  1. oerg866
    Apr 3, 2009
    Hello.
    I'm working with Motorola 68000 assembly on a Sega Genesis console.
    I have a code here wich works in certain emulators but not on the real console nor ReGen.
    Code ( (Unknown Language)):
    1.                 move.l    #$00000DE3,d0
    2. sndrvloop:
    3.                 move.w    (a0)+,(a1)+
    4.                 dbf    d0,sndrvloop
    This move.w (a0)+,(a1)+ causes the thing to lock up. Only if I set d0 as or below #$000000FF it works (however the wanted function is not achieved).
    Is there any way to express this command by something else that doesn't lock it up?
    Greetings
    Oerg866
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The reason for the lockup is rooted in the values you have in a0 and a1. If the processor starts a bus cycle and nobody is there at that address to give a DTACK then you're hosed!
