m5l8279p-5
Discussion in 'The Projects Forum' started by jhdtrinh, Jun 17, 2014.
  1. jhdtrinh
    Jun 17, 2014
    hello im new. please advice on this chip. from mitsubishi m5L8279p-5. if i replace it from the circuit does it need to be reprogramed?
  2. absf
    Dec 29, 2010
    1,493
    374
    Though it is called programmable keyboard/display, it is actually programmable from the host connected to it. Functionally it is the same as the Intel 8279 chip. See datasheet attached.
    Allen
  3. jhdtrinh
    Jun 17, 2014
    thank you absf. i will replace it now hope it works. it belongs to a 20 button display part. none of the buttons respond now. i found some corrosion at the pins on this chip.
