M51161P datasheet
Discussion in 'Electronics Resources' started by electronics_shamim, Apr 30, 2007.
  1. electronics_shamim
    Apr 28, 2007
    10
    Sirs,
    Can anyone help me out finding datasheet of M51161P which is used in Stereo Tape Recorder? However, M51162P datasheet available. Is both the IC function & pin-out configuration same?
    Awaiting early response...
    Shamim-India.
  2. mozikluv
    Jan 22, 2004
    1,437
    have you check if the 62 has the same # of pins? if so compare the power pin and gnd pin if they match. likewise with the output pin. the 62 could be the replacement of the 61. your best source of info will be from mitsubishi electric who is the manufacturer.
    moz
  3. electronics_shamim
    Apr 28, 2007
    10
    Sirs,
    The IC M51161P and M51162P has both 20-Pin DIP. But, basically M51161P is used in Stereo Cassette Recorder (Playback/Recording & of course, ALC). M51162P has also the same parameters. But, to tell exactly the pin-outs of M51161P is difficult, as datasheet not available. However, I do already have the datasheet of M51162P.
    If possible, pls confirm whether it can be directly replaced, as the set is dead, so it is difficult to know rest.
    regards,
    shamim_India.
  4. electronics_shamim
    Apr 28, 2007
    10
    Sir,
    Pls let me know Mitsubishi website address of semiconductors, so that i can have some info. on the same.
    regards,
    shamim
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  6. mozikluv
    Jan 22, 2004
    1,437
    since you have the datasheet of the 62 you would now know what components are connected to those pins and compare them to the ones connected to the 61. Not unless you don't have the board of where the 61 is placed. you might be confused at the schem coz its assigned as a test circuit. the parts used are basically the same as in the actual circuit except for some parts where they inject/receive their test signals.
    moz
  7. electronics_shamim
    Apr 28, 2007
    10
    Ok Sir. I will try to verify the pin config of 62 with 61 and shall revert back later. Your co-operation is always solicited.
    regards,
    shamim_India.
