Hi again Rifaa my friend, sorry for the long delay, but i had to do this a little bit each time, so it looked i would never finish, but finally i did everything you asked me to, hope this helps you to understand what's going on with this
1. Image 1
2. Image 2
3. It looks ok, if it wasn’t the diode check would be 0 right? It gives 1, there is no contatc between sides
4. This diode shows 019 for both sides, it has contact between sides on the circuit, should i desolder it?
5. resistance 1, no contact
6. Resistance 1, no contact
7. Image 3
8. It has no contact for B+, for ground is has contact on pins 5 and 6, and don't know if this helps, but i took the ic from it's base, and on it's bottom was the code 0817kr0232, don't know if tis is something related to the kind of ic it is, or if it's only a number. about the real parts number on the top, i already tried several things, and didn't got not even a number sorry for that, but it's as yousaid, they really don't wanted people to know the parts numbers for what it looks
9. The inductor (R50_0712) has contact with B-
10. Done
11. and 12 Image 4
Scaled picture of both sides of this unit – Image 5
My DMM, in the mode i used to check all the resistances, so please if i’m not using the right mode, please tell me which one i should – Image 6
Now the images:
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
Hope it’s everything as you asked, and thanks for all the trouble you’re having with this!
1. Image 1
2. Image 2
7. Image 3
10. Done
11. and 12 Image 4
Now the images:
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
