M.S.
Discussion in 'Math' started by fpoint, Apr 29, 2015.
Thread Status:
Not open for further replies.
  1. fpoint
    Mar 28, 2015
    11
    I will present you a math composed of only two basis (natural and realistic basis)
    Current mathematics (CM.)
    Natural Base
    -natural straight line the main axiom, its beginning or end point and natural straight line a defined length and with two points
    NOTATION - natural straight line (lower case), points (capital letters or numbers (when specified point uploads metric (such as the number line)))
    -natural gaps negation natural straight line , natural emptiness and emptiness is defined with two points
    NOTATION - natural gaps (small underlined letter)
    -basic rule merger - natural straight line and natural gaps are connected only points
    -basic set - all possibilities defined theorem
    (CM.)does not know the natural straight line , point is not defined, knows no natural gap, is not defined by basic set
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    So what's your point?
  3. studiot
    Nov 9, 2007
    5,005
    515
    Note this nonsense is currently doing the rounds of technical forums (again, this is not the first time)
  4. WBahn
    Mar 31, 2012
    18,084
    4,917
    I vote TROLL!
    DerStrom8 likes this.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Sic 'em!
  6. fpoint
    Mar 28, 2015
    11
    Can you get a lot of mathematics without axioms, when you simplify the possible new discoveries
    Theorem - Natural straight line (natural gap) are connected in the direction of the points AB (0.1)
    PROOF - straight line (gaps) b (\underline{b}) -defined AC (0,2)
    - straight line (gaps) c (\underline{c}) -defined AD (0,3)
    infinite one way straight line (oneway infinite gaps) ∞ (\underline{\infty}) defined A∞ (0, ∞)
    (CM.) - straight line (not from the natural basis), there is gaps, a one-way infinite straight line the (semi-line (not from natural base)), one-way infinite gaps does not exist
  7. #12
    Nov 30, 2010
    16,664
    7,312
    You have the power.
    Personally, I can't understand a bit of this, but my top level of math is algebra.
  8. djsfantasi
    Apr 11, 2010
    2,900
    870
    SECONDED!!
  9. studiot
    Nov 9, 2007
    5,005
    515
    I wish I could remember the name of the 'member' who posted this same stuff here a few years ago.
    Perhaps someone else can so we can find that thread.
  10. djsfantasi
    Apr 11, 2010
    2,900
    870
  11. BR-549
    Sep 22, 2013
    2,167
    416
    Can you put that in a word problem for me?
  12. WBahn
    Mar 31, 2012
    18,084
    4,917
  13. studiot
    Nov 9, 2007
    5,005
    515
    Yes, I think that was the user, but I don't think that was the tread, he had several and one had lines and gaps drawn exactly as this one.
    Also the user was one of those that never actually responded to a comment, but just kept adding more and more (junk ?) to the pile with each successive post.
  14. djsfantasi
    Apr 11, 2010
    2,900
    870
    Is the drug best taken ice cold and drunk with pizza?
  15. studiot
    Nov 9, 2007
    5,005
    515
    Now you are talking.
  16. fpoint
    Mar 28, 2015
    11
    I answer only to meaningful questions, if from what I told you he presented did not understand then you can not help (because knowledge can not teleport into your brains, or learn or do not learn), you must have some mathematical knowledge ...
    Theorem - there is a relationship between the points 0 and all points one-way infinite straight line(one-way infinite gaps) including points 0
    PROOF - relationship points 0 points 0 and the number 0
    -relationship points 0 points 1 and the number 1( \underline{1})
    -relationship points 0 points 2 and the number 2 (\underline{2})
    basic set of natural numbers N^o=\{0 , 1 , 2 ,3 ,4 ,5 ,...\}
    basic set of natural numbers gaps N_p^o=\{0 , \underline{1} ,\underline{2} ,\underline{3} ,\underline{4} ,\underline{5} ,...\}
    (CM.) - natural numbers are given as an axiom, there is no natural gaps numbers (there is this form, but do not call numbers (\{0,0\}\cup\{a,a\} a\in N)
  17. Alec_t
    Sep 17, 2013
    5,967
    1,134
    Playing devil's advocate here, how would a fraction, such as 2/5, fit into this scheme of things?
    Are the gaps quantised or continuous?
    Why is the line only 'one way'? What about negative numbers?
    Can you give us an example of a real-world application of this theorem?
  18. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    I have nothing with math, but I see it this way.
    The upper part are the real numbers, they can have ANY value:
    The lower line are integer numbers, they can only be whole values.
    Bertus
  19. studiot
    Nov 9, 2007
    5,005
    515
    The person you are copying is asking for help on other pure mathematical forums to prove his stuff (with no success).
    If he doesn't understand it, how can you and how can we, thirdhand?
  20. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Definitely a troll.
Thread Status:
