M/A-COM Power Module Land Pattern Help?
Discussion in 'Electronics Resources' started by sarap, Aug 24, 2010.
  1. sarap
    Aug 24, 2010
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you can't find the part in a device library, the PDF gives the pin spacings and offset from the case edge. Place pads on those spacings and print the pattern. Check to see if the pads match the pins.
