LXM23D and BCH Servo drive system
Discussion in 'Homework Help' started by MWUsman, Feb 23, 2016.
  1. MWUsman
    Feb 22, 2014
    Dear Members,
    I'm using the above mentioned system on a labelling machine as the label sender. During normal operation the machine stops and the drive displayed AL017 alarm message. I found the below details in the manual regarding the AL017 alarm :
    Parameter data error when writing into EEPROM.
    Check the parameter settings.
    Procedure:
    1. Press the S button on
    the HMI keypad and check
    the parameter shown on
    the HMI display.
    2. If E320A is displayed (in
    hexadecimal format), it
    indicates it is parameter
    P2-10. Check the parameter
    settings of P2-10.
    3. If E3610 is displayed (in
    P6-16. Check the parameter
    settings of P6-16.
    Upon pressing the S button however, I got 'E0603' displayed instead of the above stated ones. The parameters (P2-10 and P6-16) were checked and found to be correctly set. Nothing regarding E0603 code was found in the LXM23D manual. Can anyone please suggest a solution? LXM23D and BCH Servo drive system
    Kindest Regards.
