LXHL-LW3C drive circuit
Discussion in 'The Projects Forum' started by smilem, Jan 15, 2009.
  1. smilem
    Thread Starter Senior Member
    Jul 23, 2008
    133
  2. smilem
    Jul 23, 2008
    133
    Here are specs:
    Luxeon III Star LED - White Lambertian, 65 lm @ 700mA
    LXHL-LW3C Specifications:
    Lumens @ 700mA: 65 lm
    Max Continuous Current: 1000 mA
    Forward Voltage : 3.9 Vf
    Dominant Wavelength: 5500 K
    LED Type: Star
    Radiation Pattern: Lambertian
    Weight: 5.5g
    I see commercial power supplies are rated for 700mA of power for 3W LED like I have and 350mA for 1W LED.
    My power supply: 12V Here is how I calculated the resistor for LM317T 1.5Amps IC:
    (12v-3.9v)/0.700mA=11.571/0.700=16.53Ohms
    Are my calculations correct??? because this calculator here:
    http://www.reuk.co.uk/LM317-Current-Calculator.htm
    Shows me that I need 1.8Ohms 0.88W resistor
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Your calculations are wrong.
    The website's calculations are based upon a typical Vref of 1.25v. Yours may be as low as 1.2, or as high as 1.3. You will need to measure it to make certain, by connecting a 100 Ohm resistor between the OUT and ADJ terminals, and connect 3v to 30v between the IN and ADJ terminals. Measure Vref between then OUT and ADJ terminals using an accurate DMM (digital multimeter).
    You will need a heatsink for both the LED, and for the LM317T.
  4. mik3
    Feb 4, 2008
    4,846
    63
  5. iONic
    Nov 16, 2007
    1,422
    68
    Some have found simple ways to build regulators. See the website
    Instructables. I can not vouch for their accuracy or quality.
  6. smilem
    Jul 23, 2008
    133
    Thanks, I now changed my LED to 1W 350mA version, it suppose to give me 90% CRI rating versus 70% for "cold white" versions.
    I'll measure my Vref of voltage and post it.
    BTW anyone knows how to know Luxeon LED model? My LED has no writings etc.
  7. iONic
    Nov 16, 2007
    1,422
    68
    Do you have a closeup pic of both sides?
    Maybe it's a fraud!
