LVTTL I/O over current
Discussion in 'General Electronics Chat' started by Baron, Nov 30, 2010.
  1. Baron
    Thread Starter Active Member
    Jun 15, 2009
    31
    I want to use the cool runner II (XC2C64A) to drive magnetic buzzer which has coil resistance of 15 Ohm . The coolruner spec defines max 20mA @ 3.3v from the I/O which is definitely not enough.In spite of that limitation, I tried to connect it the Coolrunenr and was very pleased from the sound level pressure I got.
    Does the Coolrunner contain over current protection inside(I couldn't find any mention about it)? Is there a risk of I/O burning? Or maybe the I/O will drive as much current as it can?
  2. retched
    Dec 5, 2009
    5,201
    313
    ....My friend....
    Why even tempt fate? Send extra money to my address. ;)
    You should be using an transistor to switch a buss line to the buzzer.
    A current limiting (base) resistor for the transistor and a current limiting resistor to the buzzer.
    Does the buzzer have any requirements?
    As for your controller.. Its over current protection is blowing up ;)
    Actually, over heating the I/O can cause lifetime shortening, transistor problems, fuse problems, etc..
    Limit the current ALWAYS.
    The datasheet mentions nothing about current limiting. That means you design as the answer is NO. ;)
