LVDS in FPGA
Discussion in 'General Electronics Chat' started by Rahul Soni FPGA, Feb 28, 2014.
  1. Rahul Soni FPGA
    Feb 28, 2014
    HI,
    I am Rahul
    How LVDS works that I know , but only theory.
    My Quest: if I apply +2 to +input(i1) and -2 to -input (i2) at sender side then what is output at receiver side.
    is it like : vout = i1 - i2
    if yes then vout = 2 - 2 = o... how its possible
  2. kubeek
    Sep 20, 2005
    4,689
    806
    That would be 2 - (-2) = 4, just like any other differential signalling. Seems your theory is lacking a bit as well.
    Anyway, what does this have to do with the e-book? I doubt that it covers LVDS or FPGA.
  3. Rahul Soni FPGA
    Feb 28, 2014
    if I send 2v & -2v volt through LVDS I/o of FPGA then receiver LVDS FPGA got 4v ?
    what happen in receiver side ?
  4. MrChips
    Oct 2, 2009
    12,635
    3,453
    As kubeek indicated, you need to understand differential signaling a bit more.
    RS-422, RS-485, USB are all examples of differential signaling.
    What is important is not that 2 - (-2) = 4, but the fact that the signal to noise ratio (SNR) and common mode rejection ratio (CMRR) are improved significantly.
    Any noise that is common to both signal lines is eliminated by subtraction. The receiver can better separate the signal from noise.
  5. Rahul Soni FPGA
    Feb 28, 2014
    Thank you for your support
    ya I know that SNR and CMRR that all stuff, but I feel to much confusion about vout =4 at rcver side.
    how Receiver react with 4 volt ? recevicer consider 4 volt or 2 volt .
    I know noise will subtract but wat about voltage ?
    receiver accept (4 volt) more voltage than sender in LVDS
  6. atferrari
    Jan 6, 2004
    2,666
    784
    Noise is also a voltage, let's say...
  7. MrChips
    Oct 2, 2009
    12,635
    3,453
    I already told you to forget the 4V.
    LVDS chips for computer systems do not use -2V.
    The purpose of LVDS is to transmit and receive data at very high data rates and thus LVDS buses and data paths must be treated as transmission lines.
  8. Rahul Soni FPGA
    Feb 28, 2014
    Thank you very much
    Now I understood wat you are trying to explain.
    can you forward me LVDS internet link to understand deeply with example?
