LVCMOS totem-pole output needs pull-up/down resistor for what?
erasmooth
Joined Aug 5, 2013
In which case LVCMOS totem-pole output needs (internal or external) pull-up/down resistor?
Usually, totem-pole type I/O has (internal or external) pull-up/down resistor only when it's an input pin. But, I know for some time it has pull-up/down resistor even when it's an output pin.
Why is that?
Papabravo
Joined Feb 24, 2006
21,228
If you look closely at the schematic for a CMOS output you will see that actual resistors are uncommon. What you will see is a FET configured as a resistor. Is that what you are talking about? Give us a part number or a chip schematic.
erasmooth
Joined Aug 5, 2013
TI TMS320TCI6608 device. EMIF16 output pins. For example, EMIFOE_L (output enable) is Hi-Z output LVCMOS type. It has internal pull-up of 1uA. I think this LVCMOS output has the "active" pull-up but at default it's Hi-Z state, so internal pull-up is required. At run-time, the output has two pull-up at the same time, one is "active", the other is "passive." What kind of effect does the internal "passive" pull-up have?
http://www.ti.com/lit/ds/sprs623d/sprs623d.pdf
WBahn
Joined Mar 31, 2012
30,082
If it has the option to produce a Hi-Z output, then it is not a true totem pole output. The totem pole legs can be disabled (usually by means of series FETs in both the upper and lower legs) and so then you would need a pullup/pulldown in order to establish the state (or have the design such that exactly one output connected to the node is actively driving it at all times).
