what is the sensor I should use for digital lux meter
photodiode or LDR.. these directly work on light interaction. you will have to use ADC for conversion. a small and powerful controller would be ATTiny13what is the sensor I should use for digital lux meter
You can measure light without calibration, but of course you're right that the result won't be in lux units without calibration.If you want to measure light, it must be calibrated with a known accurate light meter.
by Jake Hertz
by Jake Hertz
by Aaron Carman
