Luminosity of standard RED led
Alec_t
Joined Sep 17, 2013
14,330
Welcome to AAC!
The datasheets for specific LEDs will have the answer. There isn't a 'standard' that I'm aware of.
dl324
Joined Mar 30, 2015
16,943
Ditto the welcome to AAC!
Luminous intensity is dependent on LED type and current. Manufacturers typically specify at 20mA.
If you need to know intensity of an unknown LED, you can use a sensor to measure. I've used products from TAOS.
Roderick Young
Joined Feb 22, 2015
408
What you can do is go to a vendor site like digikey.com, mouser.com, etc., and search LEDs. For example, if you go to mouser, go to Optoelectronics -> Led Indication -> Standard LEDs (through hole), and select the color Red. That narrows it down to 1339 choices, with luminous intensities from 0.1 mcd to 65000 mcd. Intensity is a function of how tightly the light is focused, of course. An LED with a narrow viewing angle will have high intensity compared to the same thing with a wide viewing angle. It could be the same physical LED die inside a package with a different lens, that's all.
