That's always been my approach too. Actually I was a little less methodical. I would buy the car with 70-150k miles, immediately move into it, and carry a full complement of tools everywhere I go. Always worked out for me. The only time I can remember being legitimately stranded and had to be towed to a mechanic was one time when my clutch went out. Kinda hard to fix that on the side of the road, especially with 3" of ground clearance.20K (mileage) is probably pretty safe. My style is to buy something with 50k to 70k and hold back $1000 to fix the real reason they sold it. A few months on the back porch fixing everything, and THEN I move into it.
You know, check the brakes and bearings, replace if necessary. Go through the alternator/battery system, air conditioning, water leaks, light bulbs, cruise control, U-joints...the works. I'm just too old to do all this in a week or two, but I can replace an engine or rebuild a transmission if necessary. Problem is, a woman won't put up with this approach. One of my friends used my place to rehab a used car for his wife and, when we presented it to her, she said, "It's about time!"
It was wonderful soaking in the gratitude...not.
My first "real" 40 hour per week job was fixing vacuum tube TV's. Today's big screen stuff is not very similar except it uses the same block diagram. When I see both horizontal and vertical jitter, I know which area it's in because both sync pulses are derived at the same place.How do you fix a horizontal sync problem in your line of work?
You run the sink through the reverse osmosis unit which converts it from horizontal to vertical. Then, you repair the loose ground so it doesn't flip back. Then attach the heat pump to get hot and cold water.How do you fix a horizontal sync problem in your line of work?
The short answer is, Air Conditioning is my day job.How do you fix a horizontal sync problem in your line of work?
The nuclear Navy did some experiments with an alloy of sodium and potassium metals - each an excellent conductor of electricity and heat. The interesting part of this alloy is that it is liquid at room temperature so it can be pumped. Pumping heat like that allows amazing heat transfer - especially because the boiling point of the alloy is 800C.A thermal superconductor is like a electrical superconductor, except with heat instead of electricity. The end result is a material that is the same temperature throughout, even if one end is in a cryogenic environment and the other in a furnace. It will allow heat to flow through it with 100% efficiency, no moving parts. I believe their are low temperature examples of the phenomena where superconductors used to only exist. I could be mistaken about it existing, but when you think about it most heat pumps involve pumping liquid materials around just to transfer heat, such as the radiator on a car.
Yes, I misunderstood your question. You are looking for the magic fairyland version and it hasn't been adapter for residential use yet.A thermal superconductor is like a electrical superconductor, except with heat instead of electricity. The end result is a material that is the same temperature throughout, even if one end is in a cryogenic environment and the other in a furnace.
Yes. It's very difficult to get the gates at the right height. Even after I scrape the snow off, I have to consider how high the lawn grass will be after it resumes growing in the spring.Isn't that a tough job with all the snow?
Thread starter | Similar threads | Forum | Replies | Date |
J | Do you know what thread type this motor would have? | Technical Repair | 6 | |
Re-Upload on previous thread | Microcontrollers | 1 | ||
Am I lucky or a hidden soul directs me ? | General Electronics Chat | 38 | ||
must be my lucky day | General Electronics Chat | 20 | ||
T | Scored lucky with a 42" LCD TV | General Electronics Chat | 22 |
by Aaron Carman
by Duane Benson
by Duane Benson
by Duane Benson
