ltspice zvs simulation
Discussion in 'General Electronics Chat' started by bug13, Jun 14, 2014.
  1. bug13
    Feb 13, 2012
    1,214
    38
    Hi guys
    I tried to simulate a zvs driver circuit, but I don't get anything out, how can I make it work?
    Vcc = 24V
    • zvs.asc
      File size:
      3.4 KB
      80
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Isn't U3 upside down?
    Edit:
    Skip the initial operating point solution.
    Set the sim time for 10ms or so, you get a more interesting result :).
    bug13 likes this.
  3. wakibaki
    Jun 12, 2012
    7
    All my LTSpice sims use a voltage source connected across Vcc and Ground. Perhaps you're using a feature I'm not familiar with?
    w
  4. crutschow
    Mar 14, 2008
    13,508
    3,384
    You need to post the complete circuit including the driver and the voltage sources.
    You circuit has no connection between the driver source and the MOSFET inputs.
    The MOSFET gates need to be driven by the out of phase signals from transformer K1 (not shown).
    K1 must be driven from a bipolar signal (or the input capacitively coupled) to avoid core saturation.
    bug13 likes this.
  5. bug13
    Feb 13, 2012
    1,214
    38
    Thanks, this fixed my simulation.
  6. bug13
    Feb 13, 2012
    1,214
    38
    My K1 is for another simulation, I just have a bad habit of have two different simulation on the same file.
    But thanks for pointing that out, I will try that.
