Hello!
I'm current sketching a sensor circuit with wheatstone bridge. The resistance can vary between 1 ohm to 1 megaohm depending on the conductivity of liquid.
As the output is ac voltage, i purposely connect a diode to the output so that it can block out the negative voltage reading. The positive voltage reading is important for data processing in A/D converter.
I have been trying to simulate it via LTspice but there is an error. How can I correct the circuit? Is there any way to filter out the negative reading instead of using diode?
I have uploaded my file below. Any suggestion and help would be kindly appreciated.
