I just downloaded the latest LTspice. It is re-written to run in 64-bit mode. In fact, it now installs in the Program files folder instead of the Program files (X86) folder.
My first impressions are not good.
First an irritant. When the program is launched, it comes up in a reduced-size window. The window is too small to show all of the tools. So, the very first thing you must do every time is make the window full screen.
The _very_ first time I ran the program it crashed. Not very encouraging. I have had it crash more the once.
I wanted to try it with some of my existing circuits. Being lazy I figured that I would just rename the .Lib folder in the LTspice XVII directory and then copy my .Lib from the older LTspice IV folder.
Well, the copied folder was not found even when I restarted LTspice XVII. After a bunch of tooth grinding, I found that even though the .Lib folder is in the LTspice XVII folder, the .Lib folder _actually_ used is in the C:Users\Richard\Documents\LTspiceXVII folder on my PC.
I am hoping that the new version runs faster but I have not done any comparisons yet to see if that is the case.
One difference I have noticed is that the plotting of the waveforms is jerky instead of smooth. By this I mean that the waveforms are not drawn a horizontal dot at a time but instead a bunch of horizontal dots are spit out at once.
Anyone else have any experiences with LTspice XVII?
