LTSpice - varying frequency along time
atferrari
Joined Jan 6, 2004
4,770
LTSpice simulation.
I could not find a way to implement this:
a) Testing a circuit fed with a fixed amplitude sinusoidal voltage source varying frequency along a certain period. Say, in 2 seconds, between 6KHz to 450 Hz with 0.5 V amplitude.
b) Later I would like to test the same circuit in the same period at a fixed frequency with a varying amplitude.
c) And last, eventually, mixing both options.
Is such a thing possible? I fear I am out of luck here.
Please note:
I am not trying to do a .tran simulation; my test is in one pass along time and stepping a parameter is not what I need either (well, the way I know to use it, at least...).
Suggestions appreciated.
Edit:
Yes, it is a .tran simulation. My bad.
/Edit
MikeML
5,444
V(in) goes from 0V to 2V (because time goes from 0s to 2s) and V(B1) = V(in) = time.
V(F) is 10Hz when V(in) is 0V specified by space=10).
V(F) is 50Hz when V(in) is 1V specified by mark=50).
V(F) is 90Hz when V(in) is 2V because the slope is 40Hz per volt.
