ltspice, using the command thingy
Discussion in 'General Electronics Chat' started by ninjaman, Jan 30, 2014.
  1. ninjaman
    May 18, 2013
    306
    hello
    I have ltspice and im following the recommendation of users on here. I want to use the text editor thing. the thing where you put in the title then the values with spaces between. like this,
    this circuit example
    v1 1 2 8
    r1 2 4 5
    r2 3 5 7
    .end
    I cant find this on ltspice. do I have to put in the circuit diagram first? or can I just write this in a window. I have looked at tutorials but none on this subject within ltspice. I have found how to make a schematic and basic testing but I would like to learn this as it seems quick and simple and I have failed when trying to make circuits using the schematic. I get an error with syntax. anyone know of a thorough guide on ltspice, it all seems like little bits here and there. is there one comlete manual?
    cheers
    simon
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Google LTSPICE Tutorial
    The netlist file is created automatically when you simulate a schematic: Normally, you would not be editing the netlist.
    Here is a running LTSpice simulation, its plot window, the schematic file (Draft145a.asc)
    The created netlist (Draft145a.net), which you can open in the LTSpice window.
    ps. The forum software wouldn't let me upload the .net file, so I had to rename it Draft145a.net.txt. Get rid of the .txt to put it back in it's original form.
  3. crutschow
    Mar 14, 2008
    13,477
    3,362
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can view the netlist by right-clicking on a blank area of the LTSpice schematic, selecting "View" from the bottom of the popup dialog, and then "SPICE Netlist" from the next popup. However, you can't directly alter the netlist; you need to add/remove/change things in the schematic itself.
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Have you looked at the 'Help' (F1 key) /Modes of Operation/Externally Generated Netlists ?
